My touchpad was connected to the pc and when I disconnected it, he has made a restart and now it will not boot...
and webos doctor doesnt works, because it stops at 12%
sorry for my bad english
droidyman wrote:What was the prior step that you completed? - I think this will help us to help you.
I patched my HP Touchpad with this Android release without issue.
GamerDaniel wrote:droidyman wrote:What was the prior step that you completed? - I think this will help us to help you.
i removed android from my device, then the cable and then my device has restarted
i only see this logo
and the webos doctor doesnt works > it stops at 12%
GamerDaniel wrote:many thanks guys
my touchpad is working again:)
smarquis wrote:I am pretty sure my touchpad might be bricked but I wanted to double check. I booted about 3 different times into the android build successfully but on the fourth time around my touchpad's screen flashed real quick and then gave me an image of a battery with a question mark in the middle. Now my computer running windows 7 64-bit will not recognize my tablet. Any thing I might be able to try?
