when I do this:
- Code: Select all
mount -o loop -t ext3 /dev/mapper/store-android--system /tmp/system/
I get:
- Code: Select all
mounting /dev/mapper/store-android--system on /tmp/system/ failed: Invalid argument
Thanks
mount -o loop -t ext3 /dev/mapper/store-android--system /tmp/system/mounting /dev/mapper/store-android--system on /tmp/system/ failed: Invalid argumentsmartelf wrote:Hello, I am having a problem with step 4.
when I do this:
- Code: Select all
I get:
- Code: Select all
Thanks
lvs
lvs
LV VG Attr LSize Origin Snap% Move Log Copy% Convert
android-cache store -wi-a- 320.00M
android-data store -wi-a- 1.00G
android-etc store -wi-a- 32.00M
android-persist store -wi-a- 16.00M
android-system store -wi-a- 320.00M
filecache store -wimao 136.00M
log store -wimao 24.00M
media store -wimao 11.09G
mojodb store -wimao 256.00M
root store -wimao 568.00M
swap store -wimao 400.00M
update store -wima- 16.00M
var store -wimao 64.00Msmartelf wrote:Here it is:
- Code: Select all
lvs
mount | grep system
c:\Program Files (x86)\Palm\SDK\bin>novacom -t open tty://
root@ErnestsHPTouchPad:/# mount | grep system
mount | grep system
root@ErnestsHPTouchPad:/# cd tmp/system
cd tmp/system
root@ErnestsHPTouchPad:/tmp/system#
root@ErnestsHPTouchPad:/tmp/system# ls
ls
root@ErnestsHPTouchPad:/tmp/system# cd /
cd /
root@ErnestsHPTouchPad:/# mount -o loop -t ext3 /dev/mapper/store-android--syste
m /tmp/system/
m /tmp/system/
mount: mounting /dev/mapper/store-android--system on /tmp/system/ failed: Invali
d argument
root@ErnestsHPTouchPad:/#smartelf wrote:I get nothing
- Code: Select all
mount | grep system
cd tmp/system
ls
cd /
m /tmp/system/
m /tmp/system/
d argument
smartelf wrote:I tried novacom, novaterm and putty, all with the same results
BusyBox v1.17.3 () multi-call binary.
Usage: mount [OPTIONS] [-o OPTS] DEVICE NODE
Mount a filesystem. Filesystem autodetection requires /proc.
Options:
-a Mount all filesystems in fstab
-r Read-only mount
-w Read-write mount (default)
-t FSTYPE Filesystem type
-O OPT Mount only filesystems with option OPT (-a only)
-o OPT:
loop Ignored (loop devices are autodetected)
[a]sync Writes are [a]synchronous
[no]atime Disable/enable updates to inode access times
[no]diratime Disable/enable atime updates to directories
[no]relatime Disable/enable atime updates relative to modification time
[no]dev (Dis)allow use of special device files
[no]exec (Dis)allow use of executable files
[no]suid (Dis)allow set-user-id-root programs
[r]shared Convert [recursively] to a shared subtree
[r]slave Convert [recursively] to a slave subtree
[r]private Convert [recursively] to a private subtree
[un]bindable Make mount point [un]able to be bind mounted
bind Bind a file or directory to another location
move Relocate an existing mount point
remount Remount a mounted filesystem, changing flags
ro/rw Same as -r/-w
There are filesystem-specific -o flags.
