Change font size
It is currently Mon Feb 27, 2012 5:10 pm
touch-droid.com forum
Software
Pre-Alpha Build Progress [Updated 9/25]
Talk about WebOS and Android on the HP TouchPad
Postby DarkRedFlame » Fri Sep 09, 2011 11:54 am
CyanogenMod - Currently 60% - 70% done to a working port (Doesn't mean final)
What currently works:
COMPLETE Booting into Android
COMPLETE ADB commands via ADB
COMPLETE Touchscreen support (Multi-touch, 10 fingers)
COMPLETE Power, back/home and volume button layout
COMPLETE Bluetooth ( Fixed 9/24)
COMPLETE Softkeys
COMPLETE Sound
COMPLETE Accelerometer
COMPLETE LED (Confirmed in IRC)
COMPLETE Backlight (Confirmed in IRC)
90% Complete Wifi ( Still needs to be fixed for reconnecting to wifi, needs to be verified)
Partially Compass (Bugs need to be worked out)
Partially CPU/GPU Acceleration ( Both cores are enabled) (Video drivers need to be worked on)
What does not currently work:
Blank for now
Whats currently being worked on:
Light Sensor (Works in kernel, needs an interface written for android)
Fake SD card Mount
Power Management (Needs to be adapted to a supported android interface, having trouble with sleep)
Camera (Has video feedback VIA overlay, can't capture to disk) ( Work started 9/23)
Vibration (Needs to be adapted to a supported android interface)
Issues:
Sleep Issues for Wifi and Magnetometer
Airplane mode stays on once turned on, happens because the touchpad doesn't have a real radio interface layer.
Magnet (Touchstone Support) (Works and charges, but no event is raised to show you it's charging)
TouchDroid - Currently DEAD (More or less)
Power button and volume button layout
Camera
Bluetooth
Compass/Mag
Home button
Power Management (USB Charge Only)
Sound
Vibration
Being able to run Metal Gear Solid, the best PSX game ever made.
Wifi
IRC Logs:
<@fattire> you can use it (wifi), but something called "combo scan" needs to be added to it to get it to rescan/reconnect if it drops.. also I think there may be some kernel issue w/it at the moment..
<@ciwrl> touchpad build may fu-bar usb partition
<@ciwrl> the lvm resize has the possibility of overwriting/corrupting the usb partition
(In response to the above)
<@FatTire> okay so basically, if I'm not mistaken the touchdroid instructions for resizing the partitions/logical volumes had you basically shrink the media one and then create a bunch of new android ones using the space left over.
<@FatTire> jonpry (or maybe it was rwhitby) observed that it's a much better practice to first resize the media vfat filesystem inside that logical volume BEFORE you resize the logical volume itself.
<@FatTire> so the order would be... (actually first shut off cryptfs which I don't think they did either)... then... resize the interior vfat file system for media, THEN shrink the media logical volume that surrounds it.
<@FatTire> otherwise you have a filesystem that thinks its larger than it is, basically.
<@ciwrl> they are already focusing on delivery mechanisms (ease of install)
<@ciwrl> we'll be doing the dual boot as well
<@dalingrin> the vibrator driver works but we need to adapt it to an interface that Android likes (needs a timed_gpio interface to work with Android)
<@dalingrin> same for the battery
Last edited by DarkRedFlame on Sun Sep 25, 2011 12:43 pm, edited 25 times in total.
Reason: Updates
DarkRedFlame
Site Designer
Top
Sponsor
Sponsor
Top
Re: Pre-Alpha Build Progress
Postby ReverendKJR » Fri Sep 09, 2011 9:18 pm
That is the best "Not Working" list ever!
ReverendKJR
Top
Re: Pre-Alpha Build Progress [Updated 9/11]
Postby xiVFINISHERVix » Thu Sep 15, 2011 1:48 pm
Anything new? It's been a few days
xiVFINISHERVix
Top
Postby DarkRedFlame » Thu Sep 15, 2011 3:35 pm
xiVFINISHERVix wrote:Anything new? It's been a few days
Just updated it with some new information I have received.
DarkRedFlame
Site Designer
Top
Return to Software
Who is online
In total there is 1 user online :: 0 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Most users ever online was 154 on Thu Sep 08, 2011 7:59 pm
Users browsing this forum: No registered users and 1 guest
Birthdays
No birthdays today
